Mini 8U wheeled exclosure
20 Jul 2009
The bleak North East arm pit of Britain
Has anyone used one of these by Digitus or Samson or similar that can take say 400mm deep kip in their 460mm depth enclosure?
I dont really want an fully open rack like those made my startech etc as I want it to at least look reasonably clean given its going to be on view.
My concerns are cooling/heat retention more than anything.
Kit to go in
- Ubiquiti Dream Machine Pro (will be using this for the CCTV/NVR function too)
- Trendnet TPE-TG182 switch (Needs modding, fan sounds terrible)
- 1U brush strip
- 1U 24 port patch panel to cover both the DMP and switch
- 1U 8 port 16amp switchable/monitoring by port intelligent PDU
- 3U 88TB Storage server/NAS running 5950x and a2000 for a bit of AI play, VMs etc
Will having a funny open read and the basic vents on the sides be enough here or am I asking for trouble?
I could rear mount the PDU behind the switch and ditch the brush strip for a pair of vented 1U panels should I need to but outside of this my options are very limited.
Not wheeled, but you could easily fit castors to it, I’ve got a Linxcom 12U (they also do a 6U and a 9U):
Seem decent quality and not too expensive. I added optional 2x120mm fans to the top (silent, running at 5v from USB), and nothing comes close to overheating.
The depth is the issue with these, space is a very limiting factor so I need the enclosure to be as close to the dimensions of the deepest part being fitted to the unit as possible. I mean I wouldn’t mind something as shiney and clean as that but it just isn’t going to happen any time soon I don’t think.
I bit the bullet and went with something designed more so for audio equipment however the net result is exactly what i was looking for. So far Im very impressed with it. I think ill start a thread on the new mini homelab soon.
