Mini-ATX board with PCI or PCI-Express slot
yeah, the asus p8z77i deluxe. £159.99, has a pci e x16 slot.
mini ITX you mean, or micro atx, micro atx there is tonnes, take your pick.
Sorry, I meant Mini-ITX.
I know about the PCI-E 16X but that is for the graphics card. I need a PCI-E slot for my sound card which is not the same.
Do you mean you want to plug in both? In which case you're out of luck, mini ITX will only take one expansion card in the form factor.
If you mean just sound card then you can plug it into the PCIe x16 slot, it'll just use the lanes it needs for it's bandwidth.
I don't think there are any ITX boards with a more than one slot, I don't even think its possible to fit two slots on that size PCB.
Thanks for the replies. I need it as well as my 680GTX so it looks like I am out of luck.
I currently have a creative PCI X-FI sound card but would buy the PCI-E version if I had to but it looks like neither will be able to fit anyway.
I wanted to get the BitFenix Prodigy Mini-ITX Cube Case - but it looks like I will have to sacrifice for onboard sound instead if I want to fit my current system in it.
There is a mini-dtx form factor, which has two slots, but no one seems to make it. m-atx is the sensible choice. Not as small as mini-itx obviously, but that's the price you pay for the second card.
