Mini Cooper and AUX connection
18 Oct 2002
Nottingham
Hello,
Just brought a Mini Cooper S on a 04 plate.
Its got a single CD player with boost feature (anyone explain boost feature please ?)
In my old car (Punto) i had a headunit that had a AUX input on the front and was great for connecting up my iPhone.
Theres no input on the front of the headunit in the mini and dont really wanna buy a new head unit. I have been told i need a AUX cable which plugs in round the back of the unit.
Anyone done this before ? how much does it cost for the cable and where can i get it from ???
Any advice would be great
Thanks Ben :)
Thanks for the reply.
Was hoping for something alittle cheaper to be honest.
I dont want to beable to control the ipod with the head unit controls i can do that with the ipod controls on touch screen.
Just want a basic AUX cable that plugs in the back of the headunit and then AUX into the iphone on the other end.
Any ideas ??
Thanks ben
Evening,
Well i managed to sort it out over the weekend.
I called my local Mini dealer and got quoted £60 for the aux kit.
Looked on ebay and found it for £40, the part number matched what the Mini dealer quoted, (part number 65 12 0 308 752)
Theres some great guides over at mini2.com.
I had to remove the glove box following the guide and that was it :)
Plugged the lead in then the AUX option appears on the head unit.
Hope this helps someone else.
Ben :cool:
Evening,
Ben :cool:
Good show :)
