29 Dec 2013 at 09:45 #1 cahonis cahonis Associate Joined 21 Dec 2009 Posts 265 Hi Is there any point swapping a DVI connection on my 2nd monitor to a Mini DP to HDMI adaptor? I only use the second monitor for web etc, gaming is done on the primary which is connected via HDMI. Thanks
29 Dec 2013 at 10:50 #2 snips86x snips86x Soldato Joined 14 Nov 2012 Posts 17,976 Location Chesterfield Not really no! If you need the port for something else you will need to get an adapter which will set you back £50-60.
29 Dec 2013 at 10:57 #3 MagicBoy MagicBoy Soldato Joined 18 Oct 2002 Posts 19,382 Location South Manchester No. Same signal, different connector.
