Mini Gaming PC for GTX1070
9 Jul 2013
The Garden Tomb
Hello,
Looking to spec up a mini gaming PC that I can take round my friend's house (so has to be portable) and can hopefully fit on a shelf of my TV stand (max height 27cm).
Budget is around £900, so hoping that the GTX1070 is between £300-400, leaving £500~ for the rest.
I already have a Samsung EVO SSD, so don't require a hard drive.
How does this look? Any foreseeable issues with fitting this all in the case? (I've seen builds using the same case with a GTX780, so hopefully will be okay)
My basket at Overclockers UK:
Total: £513.60
(includes shipping: £11.70)
Thanks
Is any additional cooling needed?
I already have a few case fans sitting around, so hopefully I can fit some of them.
I currently have an i5 4670k / GTX780 / 850w PSU gaming rig, but I want to have a more portable one.
Maybe it would be better to get a mini-itx 1150 mobo and just use my existing CPU/RAM/PSU/HDDs in the Coolermaster Elite 130 case? The performance increase from the 4 series to 6 series i5 doesn't look to be massive.
My only concern is fitting my PSU in the case (current PC here)
There's only a tiny amount of space in the elite 130 for the cpu cooler as the power supply fits above the mother board, so might not have the room for that cooler. I use a 120mm aio cpu cooler, which does a pretty good job if you can stretch your budget to one.
But yeah, have a look at clearance most air coolers won't fit. Its literally like 55mm
As for the psu the case does fit a full ATX power supply so shouldn't be a problem.
This is the cooler I use and it does the job :) but if not you'll need to look at the low profile coolers.
Total: £48.65
(includes shipping: £8.70)
Hello,
Total: £513.60
Thanks
That cpu cooler won't fit. The max size is listed as 65mm and the Raijintek is 136mm.
You would need something like this:
Total: £26.69
I would also suggest a better psu. The Corsair CS is overpriced for what it is.
These are all better units. The max psu length is listed at 188mm so they will all fit. I would also add the EVGA G2 550W to the list, but it isn't stocked by ocuk.
Total: £312.58
Awesome guys, thanks for the information.
I'll definitely go for the Cooler Master Seidon cooler and the EVGA G2 PSU
