Mini Hoover to Clean inside PC.
1 Mar 2004
Kent, UK.
I have a couple of PC's that practically have fur in the bottom. I'm using compressed air to get the junk off the heat sinks etc but really need a mini hoover to get all the junk off the boards.
Can anyone recommend anything, all I can find is cheap nasty stuff?
Thanks, AStaley.
Hoovers generate static, really not a great idea to use one in a PC.
A small brush and compressed air is all you should need (bar a hoover to do your desk/floor with after blowing the crud out of the PC in the first place).
