very stableI have this one:
http://www.overclockers.co.uk/showproduct.php?prodid=MB-417-GI&groupid=701&catid=5&subcat=2071
Great boardvery stable
Stelly
For overclocking:
Asrock Z77E-ITX
Asus P8Z77-I Deluxe
Gigabyte Z77N-WIFI
For non-overclocking:
Asus P8H77-I
Intel DH77DF
Gigabyte H77N-WIFI
There are a few others but those are the most common.
Yea...so it contrast the max overclock would be around 4.4GHz (if lucky), comparing to the AsRock and Asus that has been proven to be 4.7GHz overclock capable in reviews.Can't recommend the Gigabyte Z77N for overclocking, it has no vcore adjustment.
I've heard that the H77 Gigabyte board was better than the Z77 one for over clocking?
Where have you heard that?
The H77 chipset doesnt allow overclocking. Unless that has changed.
If you have a link to a site that says h77 is better i would like to see it![]()
There's no overclocking with H77 at all iirc?
I think theyre just saying H77 is better as its no doubt cheaper.
But tbh I just built one of these Z77 Wifi boards and got 4.3Ghz without voltage change on an i5-3570k, so that's plenty.
