Mini itx / box build for GTx 1080 / i7 6700k or 6800k
19 Feb 2011
Hello all,
As title says, need help deciding on mini atx or box build . Currently bought 1080 gtx and thinking of getting i7 quad or hex core.
There is a lot of missing information here:
1. What's your current spec?
2. Will you retain any parts?
3. Will you build yourself?
4. What resolution are you playing at?
5. Most importantly, what's your budget?
Currently I'm laptop gaming with i7 4 series, 780m and 16gig ram but I just bought 1080gtx for desktop , it's founders edition and quite bulky but i want to squeeze it in small box and with cpu that is colled via pipes and liquid (believe corsair does em) would be good oc option plus dead quiet setup?
Budget around 700 for rest of stuff, did check and it looks like ram is about 80gbp 3.2k(16gig) , psu around 100 for plat 750+ corsair, i7 6700k or 6800k , cpu cooler that corsair with tubes for around 100, case corsair or other brand that has box style and good air flow. Not keen on any led stuff so if possible to switch off any of fans that has rgb its a plus, still got 2 ssd and hdd in laptop so need for storage for now unless some good 500gb ssd goes for cheap sub 90
