Mini-ITX Build £700
28 Jul 2011
Hi guys,
I'm looking to put together a high end gaming ITX build for about £700-£800. I already have a 980ti and SSDs so it would need to fit that gfx. I'd ideally like to go use water cooling for the CPU and have looked around at a few cases but quite few struggle to fit water cooling kits such as the Corsair 250D.
Thanks for the help :).
How small do you want the case to be? And what radiator size are you thinking?
I don't think the 250D struggles to fit water cooling kits though...
Looking around the size of the Corsair 250D and Bitfenix Prodigy. I'd like to be able to use the H00i or similar, but looking at the Corsair forums that raditor doesn't really fit unless you can find an older version H00i. ( isn't GtX or V2).
Think something along the lines of:
Corsiar 250D, Bitfenix Prodigy or Thermaltake Suppressor F1
i7-6700k
CPU Cooler Corsair H75
Gigabyte GA-Z170N-Gaming 5 Mini ITX LGA1151
16gb DDR4 -3200 Memory
Power Supply Corsair SF 600W Fully-Modular SFX PSU
