All stuff had arrived and I've now built the rig!!!
Specs and pictures below
CPU - i5 3570k at 4.0Ghz
CPU cooler - H60
Mobo - Asrock Z77-E ITX
GPU - XFX 7870 Core edition
RAM - 8Gb patriot black mamba 1600Mhz
SSD - Corsair 120GB
Case - Prodigy
PSU - PC Power & Cooling 500w Modular 80+
plus a white 230mm front intake
Along with
Asus 22in monitor
Cooler Master Quickfire TK keyboard
Edifier 2.1 White speakers
Motherboard in along with H60 backing plate i5 3570k and ram
Better angle, Some wires connected ended up taking mobo back out and running some cables under mobo for better air flow.
Only cables that are now visible are the 24 pin and the 8 pin cpu plug. All other loose cables are tied up behind PSU was also able to get my SSD behind there so that made things a whole lot cleaner.
Mmmm sexy XFX 7870 core edition
All in posted all okay, Time for overclock!
Completed!
CPU cooler - H60
SSD - Corsair 120GB
Case - Prodigy
Along with
Asus 22in monitor
Completed!
