- 17 Apr 2010
Hi,
I have purchased a SILVERSTONE Milo ML05B, at 99mm tall, I don't have much room to play with once the motherboard is seated, 17mm slim bluray drive is in, I estimate I will have around 70mm at best, probably more like 60-65 (not measured as it's a Christmas present).
I will be mounting a Kaveri A10-7850K when it comes out in the next couple of months.
For a while I had my mind set on Thermalright AXP-100, due to it's size 58mm but just read a good review on Tom's hardware, and the Zalman CNPS8900 was recommended, it's also priced competitively, and at 60mm tall should fit, just
I am looking for something quiet (very important) that improves on stock cooling.
Any other recommendations or experience with the above?
Thanks
Thanks
