MINI ITX case help please!
4 Oct 2020
Hi there,
I am in the process of buying a mini itx pc purely for a streaming games.
I do want a gpu as I've read it will operate streaming at a higher quality.
I really want a internal capture card. As they have been more reliable in my experience and it cuts down on external cables.
However with a GPU, most mini itx cases at the size I want only have 1 PCIe slot.
Can anyone help me source a case that will fit a gpu and internal capture card but looks like a small black box roughly around these dimensions:
36cm deep
22cm wide
26cm height
Thank you so much for your help and support in advance.
Wouldnt a capture card like the Elgato HD60s be good enough for a streaming PC? It does 1080p 60fps capture, type C USB and the image quality is pretty good from it. Also the compression from streaming means it would be more than fine.
If the motherboard has a thunderbolt port you could potentially put the capture card in a thunderbolt enclosure ?
Or just get a usb capture card.
