Mini ITX Cases and 2.5 Slot Coolers
2 Jun 2011
Galway, Ireland
Hi all,
I'm hoping to hop on the mini-ITX bandwagon and go from a HAF X down to an ITX case, but I may have hit a snag. My current GPU is a Palit Super Jetstream 980 ti, which features that oh so prevalent (and unnecessary?) 2.5 slot cooler design.
What are my options, case wise? I have ruled out the Core v1, 250d and the Node 304 might be a stretch. My first pick would be the InWin 901, as it seems to have a bit of room between the expansion slots and the PSU chamber (and it looks sexy as hell). After that I might have to jump into the mATX space and go for a Carbide Air 240 (but at least you have room to expand to SLI).
Advice? Anyone with experience in this matter? Thanks!
Hi all,
The biggest ITX case available is Evolv ITX.
Ok, does anyone know what the GPU width restriction on the Evolv ITX is?
I also looked around and found that the Air 240 has a GPU height restriction of 120mm. This once again rules out any of the larger coolers, like mine.
