Mini ITX folding/Media Centre Rig
22 Sep 2008
Liverpool
Hi,
I'm looking at a minit ITX build for a water cooled media centre rig (ie small and silent) but that I can re-use my old hardware (GTX 8800 or GTX 285) to fold in also.
Over the years I've accumulated:
1. Old Shuttle Case
2. Q6600 G0 - OVerclocks to 3ghz with no V increase on my ITX board.
3. Zotac Geforce 9300 ITX board
4. Various 2.5" mechanical hard drvies
5. GTX 285 OR 8800 depends on what I can get away with power draw wise.
6. CPU water blocks, hosing and fittings
7. 2 Gb of generic DDR 2 ram
8. 2xPhobya double width 1.120 rad
9. Llang D5 with res top
10. Liliput 7" touch screen
The idea being that the Piano black Shuttle case be modded to fit the board, and then it would sit in my front room and be controlled via the touch screen. The problem I ma having is with what power supply to use.
I want something small enough to fit into the Shguttle case, but I don't have the shuttle one - it was only an ATX one (not ATX 2.x) and also it was only 150 Watts, plus finlaly, it made a racket.
I found and inexpensive one on *** Please do not mention competitiors ** a while back, so bought that - it's made by CIT (model is M-500U) and rated at 500W. I reckon that it should do the job, but have no idea how to check what power will be used on what lane by the components I'm listing above. Any ideas?
The PSU reads:
+3.3v = 28A
+5v = 30A
+12V1 = 14A
+12V2 = 13A
+5Vsb = 2.5A
with the 3.3 and 5v coming to 120W, and the total power rating (on the unit anyway) showing as 500W.
My GTX 8800 is rated at 145W, so that was where I was going to start, but the 285 is only 204W
The CPU is 95W I think, but overclocked that'll likely be 115W
I've plugge this all into http://extreme.outervision.com/PSUEngine and that comes out at 409W, which looks fine, but because the PSU is a bit of an unknown, I'd like some guidance, reassurance, or just plain good old fashioned advise. I don't believe that a full PSU will fit intot he case with all that I have planned.
Does anyone have any experience with these PSU's?
OR, can you recommend something thats VERY small that'll handle these power requirements?
