Mini ITX Lian Li PC-05SX Build
8 Oct 2017
Hey all,
I decided it was time to build a new PC as my one as good as it is still, it's 7+ years old and the MBoard is showing signs of decay. The USB Ports are dead and have been dead for a year, the battery has died so I thought it was better to just build a new PC. I wanted to make a mini PC but one that wasn't impossible to build in but yet can be powerful enough to play games with my GTX 1080 card. So after receiving my kit from Overclockers here is my progress.
It's all up and running I just need to decide if I should install Windows 10 on my old 120GB SSD or 256GB SSD and remove my old OS.
I had some trouble with getting the machine to boot but manage to sort it :)
2x 1TB SSDs :D
Some custom - made to length cables wod really finish that off ;)
Still looks very nice tho!
Thanks :) It would be great to do if I knew how to custom make the cables, I just had to make do with what I got :/ I have some more cable adhesive clips coming so will try tidying it up a bit more :)
Very nice build, congrats!
Like mentioned a bit of cable management and this will look even better.
I like itx and I like lian li .... bui that case is grossly overpriced imo. Your pics are ok but under lit .. you simply cannot have too much lighting when especially when you have your rgb's on...
custom cables in USA ?? I think can make the cables you need...but not cheap . But then with 2x1tb ssd you going full on ;)
cablemod.com
Love it!! Your build looks great, Nice and compact... I have the Phanteks Enthoo Evolv ITX, I don't think ill go back to ATX now
