Mini ITX/Micro ATX - AMD x3 720 options?
24 Oct 2002
Portsmouth
Hi all
Intel seems to get all the love when it comes to Mini-ITX. What does AMD get in terms of SFF PC's, because as an alternative I'm also looking at AMD systems, and pondering the possibility of a SFF AMD setup using a AMD x3 720 CPU.
Hi all
If it's for gaming then there isn't one. If it's for anything else then the J&W Minix is good, though it runs a little hot.
If there was an AMD mITX gaming board out there then i think a lot of us would have gone with the X3 720 rather than various Intel set-ups. I know i would have anyway. Sadly Intel (and the Zotac 9300-WiFi) is the only viable solution in this situation.
Details of the forthcoming Gigabyte GA-2AIEV-RH:
  • Embedded Mini-ITX form factor
  • AMD Socket AM2+ supporting Phenom/Athlon/Sempron Processor (TDP under 65W)
  • AMD RS780MN and SB700 chipset
  • HDMI 1.3b supporting full HD 1080P Blu-Ray and dual Display
  • Onboard LVDS for building POS, Kiosk and E-Signage system
  • Dual Broadcom 5764M Gigabit LAN
  • PCI-E 2.0 x16 (x8 Bandwidth) slot supporting ATI Hybrid CrossFireX technology
  • 6 SATA ports / 1 CF interface supporting Boot up
Source: http://www.gigabyte.de/Products/Networking/Products_Spec.aspx?ProductID=4419. Rumour has it that this MB is already available on the OEM/SI market.
