Im basically looking to build a mini-itx system.
But as iv never really looked into this form factor before i could do with your technical knowledge and own experiences on a good spec.
Also what is best to look for and what to avoid.
The only thing i know for sure right now is i want the Bitfenix Prodigy case.
My current specs are as follows:
I5 2500k.
Coolermaster hyper 212 evo cooler.
Asus h61 mobo.
8gb 1600mhz corsair vengeance ram.
Cooler master gx650w psu.
Asus hd7850 dcu2 gpu.
hitachi 500gb hdd.
So now for the questions:
a)Will my current psu fit the case?
b)Will my gpu fit the case?
c)What are the best board options for my price range?
d)Are there any other things im going to need extra other than a new board and case?
e)Is a good overclock realistic in these cases? (mainly gpu heat issues) as i run this card with an overclock.
The budget is set at £200 including the case.
Thanks for looking hope you guys can come up with some good info for me!
(and im sorry if this has been asked numerous times before)
I5 2500k.
Asus h61 mobo.
hitachi 500gb hdd.
