MINI ITX WIFI ZOTAC BOARDS IN STOCK NOW
11 Dec 2005
Cheshire
Zotac GF9300-I-E (Socket 775) DDR2 Mini ITX Motherboard @ £99.99 inc VAT
Experience the perfect digital home experience with the ZOTAC GeForce® 9300-ITX WiFi. Harnessing the power of NVIDIA®’s GeForce® 9300 graphics processor, the ZOTAC GeForce® 9300-ITX WiFi delivers NVIDIA® PureVideo™ HD technology for flawless high-definition Blu-ray playback and superior scaling of standard-definition videos, and NVIDIA® CUDA™ technology for accelerated video processing capabilities.
The ZOTAC GeForce® 9300-ITX WiFi pairs the GeForce® 9300 graphics processor with Intel® socket LGA775 processors – Intel® Core™ 2 Duo, Core™ 2 Quad, Pentium® and Celeron® up to 1333 MHz front-side bus – for a high-performance platform that’s ready to take on high-definition video playback yet only occupy a 170mm x 170mm mini-ITX footprint. NVIDIA® Hybrid SLI™, PCI Express 2.0 x16, DDR2, high-definition audio and SATA 3.0Gbps technologies enable the ZOTAC GeForce® 9300-ITX WiFi to have expansion potential worthy of a home theater PC.
- Intel® Core™ 2 Quad
- Intel® Core™ 2 Extreme
- Intel® Pentium®
- Intel® Celeron®
-Socket LGA775
- Memory: Memory Type DDR2, Memory Speed 667/800 MHz, Slots 2 240-pin DIMM, Capacity Up to 8GB
- 3D API: DirectX DirectX 10, OpenGL OpenGL 3.2
- Integrated Wifi: Compatibility 802.11b/g
- Size: Mini-ITX
- Ports : DVI 1 (HDCP w/Audio), HDMI 1 (w/Audio), VGA 1, SATA 3 (SATA 3.0 Gbps), eSATA 1 (SATA 3.0 Gbps), PS/2 1 (Keyboard), USB 2.0 12 (6 on back panel, 6 on pin header), Ethernet 10/100/1000Mbps (RJ45)
- Cooler Passive (no fan) with unique black heatsink
- Windows 7 capability Certified for Windows® 7 with DirectCompute support
- Other: Wake-on support Wake-on LAN, Wake-on USB, Overclocking features FSB adjustments
Only £99.99 inc VAT.
ORDER NOW
Zotac ION (N330) IONITX F-E DDR2 Mini ITX Motherboard @ £124.98 inc VAT
Experience fluid and vivid high-definition video playback with the ultra-compact ZOTAC® ION platform. The mini-ITX form factor ZOTAC® ION combines a high-performance NVIDIA® ION graphics processor with a power-efficient Intel® Atom processor for the ultimate eco-friendly platform that has no troubles handling regular web browsing, e-mail, & productivity and HD video playback tasks.
NVIDIA® PureVideo HD technology harnesses the power of the ION's 16 high-speed stream processors for high-definition Blu-ray playback capabilities. PureVideo HD technology decodes HD video formats and enhances standard-definition videos with the ION GPU for flawless HD and superior SD video playback.
- Onboard Video: GeForce 9400M
- Onboard LAN: 10/100/1000Mbps
- Onboard Audio: 5.1
Model IONITX-F-E
- CPU Socket: BGA 437: FSB 533 MHz
- Dimensions: 38.40mm (H) x 177.55mm (L) x 169.93mm (W)
- Chipset: MCP7A-ION
- Memory Type: DDR2 667/800
- Package Contents: 3 SATA cable 1 SATA power cable 1 WiFi antenna 1 WiFi bracket
- Memory Slots@ 2×240pin
- SATA: 3 + 1 eSATA
- PCI Express: x16 1
- Form Factor Mini ITX
- Video Ports: D-Sub + DVI-D + HDMI
- USB: 10 (6 on back panel, 4 via pin header)
- Power Connector 20 Pin
- RAID 0/1/0+1
Only £124.98 inc VAT.
ORDER NOW
Zotac H55ITX-A-E (Socket 1156) DDR3 Mini ITX Motherboard @ £104.99 inc VAT
ake small form factor computing to a whole new level of performance with the ZOTAC H55-ITX WiFi mini-ITX platform and LGA1156 socket Intel® Core™ i3 and Core™ i5 processors with Intel® QuickPath technology. The ZOTAC H55-ITX WiFi is the perfect foundation for a high-performance small form factor PC with support for high-speed DDR3-1333 MHz memory technology and PCI Express x16 expansion, all in a miniature mini-ITX platform. Despite the miniature size, the ZOTAC H55-ITX WiFi features 10 USB 2.0 ports, 7.1-channel high-definition audio, digital optical S/PDIF audio output, 6 SATA 3.0Gb/s ports and one eSATA port for maximum expansion and connectivity. Integrated 802.11n WiFi (300Mb/s) technology delivers lightning-fast network transfers up to 300Mb/s for performance that’s up to three times the speed of conventional 100Mb/s Ethernet without the need of wires on the ZOTAC H55-ITX WiFi.
- Model: H55ITX-A-E
- Chipset Manufacturer: Intel
- GPU: H55 Express
- CPU Compatibility: Intel® Core™ i3, Intel® Core™ i5, Intel® Core™ i7 (800 series), Intel® Core™ Processors with Intel® HD Graphics
- Socket: LGA1156
- Front-side bus: Intel® QuickPath
- Memory Type: DDR3: Memory Speed: 1066/1333 MHz, Slots: 2 240-pin DIMM, Capacity: Up to 8GB,
- 3D API
- DirectX: DirectX 10
- OpenGL: OpenGL 2.1
- Expansion Slots: 1 x PCI Express x16, 1 x Mini PCI Express (occupied by WiFi module);
Integrated WiFi Compatibility: 802.11n (300Mb/s);
- Ports:DVI: 1, HDMI: 1, HDMI: HDMI 1.3a (Dolby® TrueHD, DTS®-HD Master Audio bitstream capable), VGA: With DVI-to-VGA adapter (included), SATA: 6 (SATA 3.0Gb/s), eSATA: 1 (SATA 3.0Gb/s), PS/2: 1 (keyboard only), USB: 2.0 14 (10 on back panel, 4 on pin header), Ethernet: 10/100/1000Mbps (RJ45);
- Cooler: Passive (no fan);
- Audio: 7.1-channel High-Definition Audio;
Only £104.99 inc VAT.
ORDER NOW
