Mini ITX with GeforeGTX Mobile?
22 Aug 2009
Hi,
I am shopping around to build a custom (small) ideally Vesa mounted PC.
I currently own a GTX 285, and really don't want to "upgrade" to a slower graphics chip.
Basing this purely on PassMark, http://www.videocardbenchmark.net/high_end_gpus.html I am essentially out looking for a GTX card.
Assume the case will allow one PCI-Express card, but I should aim for the lowest power consumption possible, there are vesa mounted PCs with 220W power supplies, although I would much rather have something closer to 100W! Assume that about 50W of that will be available for the GFX chip.
The only thing that comes close to the power requirements would be a mobile graphics processor.
So the question is, are there any motherboards for sale (not laptops) with built in graphics processors such as the GTX 680M?
You need a MXM 3 to PCI-E converter first, and a GTX 680M (with a cooling system that will work in a ITX case). If you get a card for Clevo machines, you might need to flash the vBIOS or tweak the driver install for it to work - don't quote me on that though. :p
