mini itx with pci 16?
6 Aug 2008
anybody know of a mother board which is mini itx, and has dual pci 16 slots? i want to use it in conjunction with the In-Win BM648, which has 2 low profile expansion slots in which i want to use in a crossfire setup with 2 ATI Radeon HD 4550's, anybody know of a board?
It's not possible I'm afriad, the Mini-ITX spec only allows for one expansion slot. The two expansion slots can only be used if you have a Mini-DTX mainboard of which there arent any.
Such a motherboard does not exist. That case won't fit those cards in. The PSU in the case won't be able to cope.
ahh ic, hmmm whats the best mini itx mobo with a exp slot? with the ability to run quadcore processors? i know that the x58 asus rampage has one but i'm looking into just normal quadcore
If you are meaning the Asus Rampage II Gene, then that is a micro ATX board - a bit bigger than a mini ITX board.
This board is very nice indeed and can run Core 2 Duo and Quad CPUs. This board has a single PCI-E 2.0 x16 slot, which is pretty much the best you can find for this board size.
There is a mini-itx x58 board?
The Asus Rampage II Gene is a micro ATX board.
There's a fair few mini-ITX boards by Zotac which have 775 sockets and are good for the best of those cpus including the quads.
*edit: I don't believe it. All my thunder stolen while I browsed Zotacs website :(
