Mini Mac
7 Nov 2011
North Yorkshire
I am looking to get a Mac Mini for my web development work at home and my focus will be in terminal in a text editor. I might occasionally pop in Photoshop.
I can afford the quad-core but I wonder if I will actually take advantage of this, and think that a RAM upgrade would be more beneficial. I would love to get the SSD but it looks to only be in the quad-core version and I couldn't afford to kit out the quad-core with an SSD.
Can anyone advise me on the best approach to this?
Thanks
The hard drive is the major issue with the Mac Mini, if I were you I'd look into seeing how easy it is to replace the HDD with a SSD yourself.
Though it does look like a lot of effort. :/
https://www.ifixit.com/Guide/Mac+Mini+Late+2012+Hard+Drive+Replacement/11716
We have one at work used for CS6 work, Photoshop, Illustrator and InDesign in the main. Anything that required heavy drive read/writes is really slow. (Note this Mac mini is 3 years old Intel Core 2 Duo P8600, the last with an optical drive.)
I can do a drive swap on a mini in about 5 minutes, it's a doddle.
You can get away without buying the special tool and sliding the innards out if you're patient/steady handed.
Thanks for the replies.
1. Would the warranty be void if I replace the hard disk?
2. Is it worth getting extra RAM? Should I get them on OC (if so, what memory) or buy them as part of the Apple package?
3. How is this SSD? http://www.overclockers.co.uk/showproduct.php?prodid=HD-027-KS
I think it is yes. However you could swap in the old drive in the event of a repair. I bought my second hand and the AppleCare has expired, so I'm fairly gung-ho about it. :D
Whatever is cheaper. RAM is RAM in this instance. Get it from OcUK.
Personally I'd only use a Samsung, Crucial or Intel drive in a Mac. I've had screwy results with other drives - particularly those with Sandforce based controllers. Running an EVO 512gb in mine, previous to that a 250gb Evo Basic - both faultless.
For the Mini you'll need DDR3-1600 (PC12800) SODIMMs (laptop memory), Crucial comes recommended or Corsair Value would suit fine:
http://www.overclockers.co.uk/showproduct.php?prodid=MY-401-CS&groupid=701&catid=8&subcat=1264
SSD wise, I had the 250GB 840 Basic - not the EVO Basic as I first thought. The 840 EVO basic has superseded the original 840 Basic by the looks of things so you can't go wrong with the drive you linked. Like I said the 500gb EVO Basic I've got now has been fantastic.
Just remember you'll need to make up a USB recovery drive when you swap the disks over to do a reinstall. :) Drop us a line if you need a hand.
Thanks, I will get the HD and then a little later the memory.
Is this what I use to make the USB recovery drive? http://www.macinstruct.com/node/508 And I use this to reinstall Mac OSX on the new SSD?
You can reinstall the OS using internet recovery in the EFI firmware. USB drive not required.
+1 on Crucial for RAM and the SSD suggestions above.
My Mac Mini arrived last week and honestly I am finding it a little slow. I am thinking about going for 16GB RAM, rather than just 8GB. Would getting even more RAM make much more difference over not getting a SSD sooner?
Okay, thanks. I will do that.
Edit: What's the difference between the laptop SSD and the basic ones?
I bought the 250GB Samsung but I can't buy the RAM until next month since the Mac Mini gave my bank account a hammering. It is definitely way too slow right now.
It's slow even with the SSD and Quad Core i7? :confused:
What's your RAM pressure like in Activity Monitor, is it swapping a lot?
+1 For SSD
The SSD I installed in my Mac mini completely changed the useability of it.
Shame it seems to mostly only run plex these days.
