you wont have to worry about the antenna etc..
Ive just found an internal card compatable with your laptop, which has a built in antenna, actually on the card.. one of these so yeah you will be ok
fothsn said:Ronaldo the antenna is wrapped around the inner of the LCD casing. Just pick up a compatable laptop wireless card and you will be okyou wont have to worry about the antenna etc..
Edit: Ignore the above about the antenna around the caseIve just found an internal card compatable with your laptop, which has a built in antenna, actually on the card.. one of these so yeah you will be ok
Ronaldo said:well i got mine today but its signal is not very good. can even find my wireless router 1 floor down or even 1 room away.
i think i should have just got a better PCMCIA
ns400r said:Where is the aerial on that card? Because I don't see one!
Also, double check that you laptop actually has an aerial already fitted and ready to connect to any card you buy, not all do.
), they have hirose micro connector (or something similar) which connects to the internal antenna in the laptop.Ronaldo said:here is the manual pic, i didnt see no cables but i didnt take mobo out.
any ways if i buy a cable where would i connect it to or lay it because i really dont want to take the whole thing apart and lose more screws
