Mini PCIe graphics cards??
19 Oct 2002
Why not, they could clearly make them. Hav you seen how small GPUs are in laptops, all they need to do is make that a mini-PCIe card. Maybe they think there is no interest, but imagine how awesome that would be to be able to have a smaller desktop, with a mini-itx with a upgradeable GPU.
Yea, GPUs are tiny on laptops, but this doesn't take into account the cooling system which is integrated into the laptop and connected to the mobile GPU by a heatpipe(s).
At the moment I think desktop GPU size is constrained by power output and required cooler size - though if you look at the low-end HTPC cards with small heat outputs then they can be very small. This one for example is low-profile, single slot and relatively short - so would work well in a small Mini-ITX build.
Card manuafacturers probably could make graphics cards with a shorter PCIE slot (eg a x4 PCIE gen2 slot generally works fine for low/mid range graphics cards) but I think the problem is demand. There really aren't many nano-ITX boards out there used by customers and they don't generally support the mainstream CPUs (as well as GPUs) people want to use, while the larger mini-ITX standard is seeing a lot of love with Z68 boards now available in this form factore. My guess is that as progress marches on it will be possible to run mainstream CPUs in such a small form factor - then will see a wave of new boards come out and a smaller graphics card connector would be demanded by many.
