Minibox - ITX - Silverstone SG05 build
3 Feb 2011
This is my 2nd ITX build, build my first one a year ago, you can see it in this thread - http://forums.overclockers.co.uk/showthread.php?t=18490351 (pictures are missing though, deleted my Photobucket account)
Specs; (items marked with an * are the ones I ordered, the rest I had lying around as spares)
Silverstone SG05 /w 450w PSU *
i3-4130 (3.4GHz, 2 cores/4 threads) *
ASUS H81I-PLUS motherboard *
MSI R9 270 Gaming *
8GB RAM (2x4 Samsung Green)
750GB Seagate Hybrid Hard Drive
DPD dropped off some stuff.
Wow, I didn't expect to get these freebies just for ordering a packet of Haribo, can't complain.
I've forgotten how tiny ITX boards are.
CPU and RAM fitted.
CPU cooler fitted, I know it's terrible, but for an i3, I don't really need anything better, I'll upgrade to a Xeon 1230 V3 someday and get a better cooler. (Probably AXP-200R)
MSI R9 270 Gaming GPU.
SG05 itself.
Everything taken off.
Replaced the stock fan with Silverstone Air Penerator (red LED)
Board fitted in the case.
GPU fitted, hardest thing to do, took some fiddling to get it inside, it's almost as long as the case itself.
Cables plugged in.
Messy cable management, one of the things I don't like about this case, it'd be nice if I had that Silverstone modular SFX PSU.
The back of the case, I'm gonna leave the stickers alone.
Good to go now.
I love how compact this case is, the fan gives it a nice glow.
Here's some petrol on the fire but Mantle does wonders to remove CPU bottleneck :D But only for games have adopted Mantle ...
Love these cases. Sold mine late last year to a friend who promptly built an i5/GTX760 based system in it, glad it's gone to a good home.
I loved putting watercooling in the front. Pity it lost you either an inch off your graphics card length or your optical drive though.
A 270 with an i3? That's a bit crazy :)
I had a budget, didn't want to spend too much, besides it's kind of temporary, I have future plans for it.
i3's decent enough, in some cases, better than the 1st gen i7 I have, noticed this with WoW, i3-4130 + 270 ran the game smoother than i7-860 + 290.
I went with all this because I wanted to let my 290 mine 24/7 at max speed.
As for the temperature, i3-4130 /w stock cooler doesn't reach more than 50c, the GPU under heavy load reaches no more than 68c, overclocked slightly, to 1000/1500.
I was thinking about getting the red LED strip, matches the GPU and the fan glow.
I'm not sure which one to get though, any recommendations? I was looking at Bitfenix's strips.
I love a good SG05. Don't worry about the cable management, you won't be much better with the modular 450W. I have one to power the Titan in my SG05 and it's just as bad! In fact, the only cable I didn't use was one of the SATA strips, so there was no point going modular (other than the Gold rating)!
The Titan is about half an inch too long, but removing a part of the front next to the fan you can make it fit. The plastic facia gives a good half inch of additional room so it covers the hole no problem.
Yeah, I really love how compact it is, so much that I'm looking for cheap SB/IB ITX board + CPU for my next ITX build that includes a Silverstone SG07 + R9 290.
Also I've edited the OP so you don't have spam click spoilers to see all pictures.
