Specs: R9 290 15.9.1 beta drivers, Asus MG279Q monitor, Win10 x64
I've been using the above monitor for just over two months with no problem, naturally using miniDP because I want Freesync. However, on booting up my PC today, the resolution on the monitor was something like 800x600, Catalyst popped up a message saying something about a displayport link failure, my second monitor using DVI was fine. Figured the easiest way to sort a failure was to unplug and replug the monitor, but since doing that, I simply get a 'no signal' when trying to use miniDP. I've now resorted to using a HDMI cable and while the monitor is now working, I dropped a lot of money on it for Freesync, so I'm after a fix! I've tried everything I can think of, unplugging both monitors, rebooting, completely powering everything off, but I can't get a signal over miniDP at all now. Nothing was shown in the device manager either.
Welcome to suggestions on how to get it working again! Worst case option is to buy a full displayport cable, which I would assume will fix the problem since it's the miniDP not working, but that's not really fixing the problem that there's something wrong somewhere.
Thanks in advance!
Edit: Tried reinstalling the 15.9.1 drivers, and noticed that I wasn't even getting a miniDP signal during post/BIOS, so I assume it's a hardware issue with either the graphics card or the monitor? Unfortunately this is the only DP monitor I have so I don't have another one to test it with. I don't suppose there's an easy way to figure out which one the problem lies with?
Thanks in advance!
