MiniDV Tapes
If your camcorder has AV-in, then you can just select AV-in and record without a video signal. If it doesn't, then just put the lens cap on and record.
I'm pretty sure my Sony camcorder has an option (onscreen, in the menus) to erase a tape, but i dont know if all camcorders do - might be worth checking the manual. Pressing the buttons on the touch screen is as easy as controlling via the PC i would think?
I've never heard of anything to erase tapes except just record over them , most people do this. I never re-use a tape , keep them all as backups [masters]. To destroy something that is on a tape in a hurry you simply leave the lens cap on and press record on the camcorder and leave it in a quite room [bedroom ,cupboard] while it clears the tape .
