minidv to DVD
import in avi if you can and use convertxtdvd (will need to buy it)
This will convert the single avi into the audio and video files for DVD
Just make sure to copy the movies to the harddrive in DV-AVI as that is the best quality, it is ~14GB per hour though.
You then need to use one of the convertor programs mentioned, I think I used WinAVI when I had a DV camera.
Why it didn't work for you is the fact you used divx2dvd which is used for converting DIVX AVI's to DVD and not DV-AVI's
