Minimalist PSU/GPU extension cables
20 Apr 2015
Can anyone recommend 8 pin to 8 pin 20/25cm ribbon extension cable. My current Seasonic PSU has ribbon type cables which are nicely minimalist, but they go from 8 pin to 6+2 which is messy, and the daisy chains from both cables dangling off the end, which are also unsightly. Also not into sleeved cables.
Cable heaven would be 20/25cm 8pin to 8 pin ribbon..... in black.
Ta Muchly.
