So I have a TJ07 in black and I'm really considering spraying the internals in matt black.
I have an old CM ATC 201 that's in bits and I just had a go at spraying one of the doors.
I applied white primer then matt black and it has come out a lot better than I expected, there are a couple of drips but its because its was hanging from a light and was constantly turning as I sprayed it.
Note to self... Make sure I hang future parts from stationary positions.
I will post up some pictures of the door once it has dried soon for all you're opinions.
