Minimising software reinstallation after major hardware upgrade?
27 Dec 2009
I'm about to perform a major hardware upgrade to my aging PC, essentially just retaining my existing case and multiple hard drives. Although some sources suggest that Windows 10 is clever enough to pick up on hardware changes I'm assuming it's still better to go for a clean install rather than clone my existing SATA SSD, so have prepared a USB stick to install Windows 10 on a new 1TB NVMe SSD that will be the system/boot drive.
My question is once I have a clean version of Windows up and running with the new hardware, what can I do to use software that is already installed and minimise the amount of reinstallation? The data will all still be there on the old drives, but how good is Windows 10 good at this and is there anything I can do to make the path easier?
Or does anyone think that just cloning the old install is the right thing to do? Sounds risky to me considering that nearly all the components are changing, unless I'm doing Windows 10 a disservice...
Windows 10 is very good at picking up new hardware.
You aren't going to waste much time by trying the old install. If you're cloning to a new drive you already have a full backup to fall back on if it doesn't work out. No risk involved.
Interesting. As far as I'm aware my old motherboard (Gigabyte Z68x-ud3-b3) doesn't support NVMe drives, so presumably I would need to boot up the new system from the old SATA SSD and then (if that works) clone it to the NVMe and make that the boot drive.
Would backing up the old system, doing a fresh install of Windows on the new hardware and then restoring from the backup make the existing programmes available? Or will I just mess up my clean install?
What cloning tool are you considering, does it have an option to create bootable media? If so, use it to create an image of the old system disk and then again to restore that to the new system.
Having done a couple of systems this way, it seems Windows 10 can cope well enough. I still had to manually install some drivers (so make sure you have at least the network card drivers for your new system on a USB stick), but Windows booted from the old system disk image on the new hardware without complaints.
Depending on what Windows license you have (retail or OEM) and whether you still want to use Windows on your old hardware, you might want/need to change the product key before re-activating Windows.
I don't think this would get you a better result than just cloning the old system disk. The main thing that prevents an application working properly after only restoring the program files directory is the absence of whatever entries the installer sticks into the registry. Trying to also restore the right bits of the right registry hive for each application, while also not over-writing the "clean" system entries is way more effort than just re-installing the application.
Any tips for a free solution that will get the job done? I've got Macrium Reflect installed but not tried this procedure with it yet.
Me neither - I'm moving from Acronis to Macrium and fall back to using Acronis' Linux-based media if I want an offline image of something as I still have the licenses.
You can create rescue media in Reflect, although it does potentially complicate the process as it uses WinPE or RE and loads drivers based on the hardware in the machine you're building the media on. So rescue media built on your old PC might not recognise the NVME in the new.
Clonezilla Live might be an alternative, although again I haven't used it myself.
