5 Jun 2011 at 23:11 #1 Rensin Rensin Associate Joined 15 Feb 2008 Posts 1,323 Looking for a rough idea on the minimum power supply i could put in my media PC/file server. Spec is Q6600 (not overclocked) 4GB RAM 7x Mixture of Hard drives (Samsung 1TB & 2TB) will eventually have 8x 2TB drives.
5 Jun 2011 at 23:15 #2 stulid stulid Caporegime Joined 17 Jan 2010 Posts 66,731 Location weston-super-mare How many SATA drives? I think Molex to SATA adapters will be needed.
5 Jun 2011 at 23:24 #3 Rensin Rensin Associate OP Joined 15 Feb 2008 Posts 1,323 they all SATA drives m8, plus already have several adapters too.
5 Jun 2011 at 23:25 #4 stulid stulid Caporegime Joined 17 Jan 2010 Posts 66,731 Location weston-super-mare http://www.overclockers.co.uk/showproduct.php?prodid=CA-148-AN&tool=5 Good price for a good PSU.
5 Jun 2011 at 23:32 #5 Rensin Rensin Associate OP Joined 15 Feb 2008 Posts 1,323 don't think i explained properly. Looking for the minimum wattage PSU the system would take. example Would a 520w Corsair PSU be enough for the above spec?
5 Jun 2011 at 23:44 #6 stulid stulid Caporegime Joined 17 Jan 2010 Posts 66,731 Location weston-super-mare Ah, Well a HX520 will be fine, although no longer available they are quality units. You could even get away with a 450w PSU as long as you dont go mad on the graphics card
5 Jun 2011 at 23:47 #7 Randomface74 Randomface74 Permabanned Joined 9 Aug 2009 Posts 12,234 Location UK Buying the "minimum it would take" is asking for trouble.
5 Jun 2011 at 23:50 #8 Surveyor Surveyor Caporegime Joined 5 Sep 2010 Posts 25,573 OcUK Swift 450W Silent Power Supply £17.99 Just joking. Don't buy that or anything like it.
5 Jun 2011 at 23:51 #9 spleenharvester spleenharvester Associate Joined 4 Dec 2008 Posts 1,812 My CX400 runs a similar spec but with an 8800GT and only 1 HDD, for reference. I think you might get away with 400W, who knows.
6 Jun 2011 at 00:15 #10 Rensin Rensin Associate OP Joined 15 Feb 2008 Posts 1,323 haha, wasn't planning on buying the minimum PSU. I was offered a HX520 PSU for a good price but thought it would not be enough power. thanks for the advice guys
6 Jun 2011 at 08:26 #11 Admiral Huddy Admiral Huddy Man of Honour Joined 17 Feb 2003 Posts 29,640 Location Chelmsford There are plenty of PSU calculators but this one seems to be pretty good from Corsair, if it helps : http://www.corsair.com/psufinder/
