Hi My nephew has a old socket 775 system with a core 2 duo E7XXX system (I cannt recall the exact model).
It's lowe powered system and they live in a tiny flat so want to reduce the size of the computer into a purpose build mATX cube case.
unfrotunately many of them do not have adequate cooling because everything is crammed into the case, some actually dont take the conventional atx power supply and prefer these small PSUs (1U) that you get in the HP microsever.
I was wondering whether it would be possible to fit a picpsu (max 160w) on this system.
Spec:
Asus p5qpl-am mobo
socket 775 cpu E7XXX (looking to upgrade to q6600 or more efficient q9400)
HD5750 gfx
1x ssd
1x optical drive
2 case fans, 1x corsair h60 cpu cooler.
Spec:
Asus p5qpl-am mobo
HD5750 gfx
1x ssd
1x optical drive
