Minimum spec for photo editing
26 Dec 2020
Hi.
I’m looking for a PC To be able to run Lightroom and photoshop for photo editing. What’s the cheapest build or prebuilt system that will capably run these programs?
Cheers.
You can run Photoshop on a quad core cpu and 8 gb of ram but it depends how long you want to wait for the task to complete.. There is also the shortage of graphics cards which are overpriced if you can get one.
Whats your budget ?
Whats your budget ?
Thanks. Would onboard graphics be sufficient? I’d be happy to spend around the £500 mark.
As mentioned above ... quad core and modern integrated will manage fine. In lightroom you'll see slight delay to adjustments. i.e. you'll slide the adjuster, and it could be a half second pause/lag before you see the image adjust type thing. A seperate GPU will reduce that lag somewhat and make the whole thing feel more responsive. Opening and export RAW files is where CPU performance plays more. More cores/threads tends to result in more performance ( to a point ). Don't get me wrong though, quad core, its still very usable ... the difference will be in terms of a few seconds per image on open/export. For light use, that doesn't really matter.
Photoshop, I found it was a similar experience, I had a quad core 2400G AMD cpu running photoshop, and there was the slight lag to some operations and brushes. Usable, but slightly laggy sometimes. Adding a seperate GPU reduced that notably. Upgrading the cpu later again to 6 core improved performance also.
But I could still achieve all I needed to if i wanted with the 2400G.
16GB RAM will suffice as well.
I think your most important issue is what monitor do you want. Monitors vary wildly when it comes to colour reproduction. On most cheaper monitors red is very orange for example. So I think the first question is to find a good monitor and go from there.
I'd look for something using a Ryzen 4650g or 4750g (they fall either side of your budget).
Either one should give more than acceptable performance.
@pp111 is absolutely right about the monitor. You'll want something with good colour reproduction and you should really pick up a display calibrator too. You can't go wrong with Dell monitors, but LG is a good bet too.
Thanks for the help guys.
I actually have a 13 year old pc.
Asus p5q pro motherboard
Intel quad q8200 cpu at 2.3ghz
4gb ddr2 ram
Radeon rtx 560 gpu (a gift from a friend as my old gpu died)
2x500gb hhd raid
Just wondering, if I upped the ram to 8gb and installed an SSD, would this make the pc usable for photoshop and Lightroom at a workable rate?
Ive been looking into monitors as well. If I can upgrade my current pc I will have more budget for a monitor.
cheers.
Historically, you had to use them to enable 30 bit colour in Photoshop. These days consumer Nvidia cards support 30 bit colour in Photoshop anyway (but not AMD cards). There's o real reason to buy a workstation card for hobbyist photo editing, considering the premium.
if you want a quadro card - buy second hand. old K2000 quadro 2GB ram is only £30...
you still need a pro card for deeper depth colours. but that is not required for hobbist photo editing as you said.
since there are no other cards in this quadrant of the galaxy, Quadro and Radeon Pro are only choice and 2nd had are pretty cheap (at the moment)
