Minor incident
31 Oct 2003
Derby, UK
Was out with some friends the other day, came to parking up for a bit and as usual we try to get the cars as close togethor as possible. When my friend was reversing there was a slight movement in my car which made me shout stop, and theres now nice scuff marks on my car, but luckily there are no serious dents as far as i can see. I shall get the pictures later but how do you think i should proceedd, what is the best way to remove the white paint which is on my car (his is white, mines green)
Rob
T cut will do the job, or if it's a little more serious then rubbing/polishing compound should do it.
A friend of mine recently told me about a polishing compound called G3 I think.
Supposed to be very good and you can pick it up for £5 or so off the 'bay.
I've got a big bottle of Farécla G3 liquid - it's a very good paint renovator but always remember to thoroughly polish and wax the car afterwards. It turned my 205 from orange to red :D
Oh cool, cheers guys, but how should i get the white of his paint off too start with?
Rob
Try T-Cut.
Lopez, could G3 remove surface scratches from paint work? My car is covered with them from the lazy winter months when I took the car to the jetwash :(
:( my poor rover, im just concerned about mixing the white and green paint and making a weird colour!
SaBBz said:
Make your friend pay to get it sorted ;)
Im tempted believe me, how much you think it would cost, ill get photos later but its a few streaks on the side of the body and on the side of the arch.
About £50-£100 by one of them guys that comes out to you I'd guess, depends how big/bad the scratches are.
