I've had my amazing 15" MBP for just over 2 weeks now, and it has been simply fantastic (first time Mac user). However I've just noticed 2 things which have spoiled it a little bit!
First thing is that the MBP doesn't sit properly on all four feet when on a table, the bottom right hand corner is a couple of millimetres off the surface, and I have to stick a few layers of paper underneath so it doesn't wobble. Sounds minor but for what is undeniably stunning build quality in the unibody, I would expect more from something that cost so much! Furthermore, I called up Apple support who told me that they have had reports from other users of the same problem, and have been advised to bring it back to the store where they will either give me a new one or replace the case. I hope this isn't a widespread design fault!
Second thing is that I've noticed my MBP running rather hot. Especially the part of the unibody just above the keyboard is very hot to the touch. I installed the iStatPro widget (which is awesome btw), and have noticed that whilst pretty much on idle, my CPU is still at least 65 degrees C. I did a bit of Googling and found that this is an acceptable temperature, however sometimes while doing nothing but a bit of web browsing and maybe with Mail open, it has gone up to >80 degrees.
Is this typical of anyone else's MBP temps? Also has anyone else experienced the uneven feet and had the issue resolved?
