Hi all,
Recently got a minor upgrade a 3770k from a 2500k, £50 from one of my mates. After watching the Digital Foundry video about the both those processors I thought I would treat my self to some new RAM as well. I waiting until I got the RAM to start looking at overclocking again.
Ive ran into 2 issues.
1. My computer won't boot correctly if I have the RAM over 1600mhz - I get a warning message that a recent Overclock or voltage change has caused it to use default settings. I've tried the XMP and manually setting it higher.
2. I can't seem to raise the multiplier higher than x39 on the CPU
RAM - Corsair Vengeance CMY8GX3M2A2133C11 2 x 4GB
Mobo - Gigabyte GA-Z68X-UD3P-B3
I reset the Bios to fail safe defaults but wasn't sure if I had to reset the CMOS? Or have I bought incompatible RAM? Should I look to get a better mobo? Appreciate any help
Cheers
Cheers
