Minor Upgrade's, Thoughts?
6 Mar 2010
Ipswich, Suffolk
Evening all!
I've had a long running issue whereby my motherboard will only recognize 4GB/6GB of my memory, Tried 2 sets (Kingston & OCZ) & after much stress settled on the fact that it was a motherboard issue (after reading ASUS forums).
I'm SO fed up of it that I decided just to upgrade the board and fit in all in a new case.
I think I'll be buying a Coolermaster HAF X, http://overclockers.co.uk/showproduct.php?prodid=CA-203-CM
Motherboard wise, I'm treating myself to a Rampage III Black edition, http://www.overclockers.co.uk/showproduct.php?prodid=MB-456-AS
Now, Assuming my memory woes will be over. Worthwhile upgrade? I run a i7 920 & a SSD so overall speed is fantastic! Would it be wise to buy a more up to date card? Using a HD5790.
Thanks in advance, Throw any questions this way as I'm really looking forward to the new case ^^
Would a lower spec board give me any benefit or is it just cost wise? :S
I'd rather buy a monster now and have the option to change CPU later :)
Change cpu? you can't really do too much better than your current cpu, for that socket, in all honesty. Get yourself a less indulgent board, and a quality cooler and milk that cpu for what it's worth.
