When I take a screenshot, it looks normal. That means it is a hardware issue right? The odd thing is if it is windows never does it. What log should I look in? I know Xorg, but any specific one?
Here is the Xorg.failsafe
[ 44.096]
X.Org X Server 1.10.1
Release Date: 2011-04-15
[ 44.097] X Protocol Version 11, Revision 0
[ 44.097] Build Operating System: Linux 2.6.24-29-server i686 Ubuntu
[ 44.097] Current Operating System: Linux Edward 2.6.38-13-generic-pae #54-Ubuntu SMP Tue Jan 3 15:11:05 UTC 2012 i686
[ 44.098] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.38-13-generic-pae root=UUID=7866d159-f3b4-4276-9bc1-1ecb3b849684 ro single
[ 44.098] Build Date: 19 April 2011 03:33:17PM
[ 44.098] xorg-server 2:1.10.1-1ubuntu1 (For technical support please see
http://www.ubuntu.com/support)
[ 44.098] Current version of pixman: 0.20.2
[ 44.099] Before reporting problems, check
http://wiki.x.org
to make sure that you have the latest version.
[ 44.099] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 44.100] (++) Log file: "/var/log/Xorg.failsafe.log", Time: Fri Sep 7 22:56:21 2012
[ 44.101] (++) Using config file: "/etc/X11/xorg.conf.failsafe"
[ 44.101] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 44.102] (==) No Layout section. Using the first Screen section.
[ 44.102] (**) |-->Screen "Default Screen" (0)
[ 44.102] (**) | |-->Monitor "Configured Monitor"
[ 44.102] (**) | |-->Device "Configured Video Device"
[ 44.102] (==) Automatically adding devices
[ 44.102] (==) Automatically enabling devices
[ 44.102] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 44.102] Entry deleted from font path.
[ 44.102] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 44.102] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 44.102] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 44.102] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 44.102] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType,
built-ins
[ 44.102] (==) ModulePath set to "/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[ 44.102] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 44.102] (II) Loader magic: 0x81ffde0
[ 44.102] (II) Module ABI versions:
[ 44.102] X.Org ANSI C Emulation: 0.4
[ 44.102] X.Org Video Driver: 10.0
[ 44.102] X.Org XInput driver : 12.3
[ 44.102] X.Org Server Extension : 5.0
[ 44.103] (--) PCI:*(0:1:0:0) 10de:0600:1043:8268 rev 162, Mem @ 0xfa000000/16777216, 0xc0000000/268435456, 0xf8000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[ 44.103] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 44.103] (II) LoadModule: "extmod"
[ 44.121] (II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
[ 44.121] (II) Module extmod: vendor="X.Org Foundation"
[ 44.121] compiled for 1.10.1, module version = 1.0.0
[ 44.121] Module class: X.Org Server Extension
[ 44.121] ABI class: X.Org Server Extension, version 5.0
[ 44.121] (II) Loading extension MIT-SCREEN-SAVER
[ 44.121] (II) Loading extension XFree86-VidModeExtension
[ 44.121] (II) Loading extension XFree86-DGA
[ 44.121] (II) Loading extension DPMS
[ 44.121] (II) Loading extension XVideo
[ 44.121] (II) Loading extension XVideo-MotionCompensation
[ 44.121] (II) Loading extension X-Resource
[ 44.121] (II) LoadModule: "dbe"
[ 44.121] (II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
[ 44.121] (II) Module dbe: vendor="X.Org Foundation"
[ 44.121] (II) Loading extension DOUBLE-BUFFER
[ 44.121] (II) LoadModule: "glx"
[ 44.121] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 44.121] (II) Module glx: vendor="X.Org Foundation"
[ 44.121] (==) AIGLX enabled
[ 44.121] (II) Loading extension GLX
[ 44.121] (II) LoadModule: "record"
[ 44.121] (II) Loading /usr/lib/xorg/modules/extensions/librecord.so
[ 44.121] (II) Module record: vendor="X.Org Foundation"
[ 44.121] compiled for 1.10.1, module version = 1.13.0
[ 44.121] (II) Loading extension RECORD
[ 44.121] (II) LoadModule: "dri"
[ 44.122] (II) Loading /usr/lib/xorg/modules/extensions/libdri.so
[ 44.122] (II) Module dri: vendor="X.Org Foundation"
[ 44.122] compiled for 1.10.1, module version = 1.0.0
[ 44.122] ABI class: X.Org Server Extension, version 5.0
[ 44.122] (II) Loading extension XFree86-DRI
[ 44.122] (II) LoadModule: "dri2"
[ 44.122] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[ 44.122] (II) Module dri2: vendor="X.Org Foundation"
[ 44.122] compiled for 1.10.1, module version = 1.2.0
[ 44.122] (II) Loading extension DRI2
[ 44.122] (II) LoadModule: "fbdev"
[ 44.122] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 44.122] (II) Module fbdev: vendor="X.Org Foundation"
[ 44.122] compiled for 1.10.0, module version = 0.4.2
[ 44.122] ABI class: X.Org Video Driver, version 10.0
[ 44.122] (II) FBDEV: driver for framebuffer: fbdev
[ 44.122] (--) using VT number 2
[ 44.125] (II) Loading sub module "fbdevhw"
[ 44.125] (II) LoadModule: "fbdevhw"
[ 44.125] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 44.125] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 44.125] compiled for 1.10.1, module version = 0.0.2
[ 44.125] ABI class: X.Org Video Driver, version 10.0
[ 44.125] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 44.125] (**) FBDEV(0): claimed PCI slot 1@0:0:0
[ 44.125] (II) FBDEV(0): using default device
[ 44.125] (II) FBDEV(0): Creating default Display subsection in Screen section
"Default Screen" for depth/fbbpp 24/32
[ 44.125] (==) FBDEV(0): Depth 24, (==) framebuffer bpp 32
[ 44.125] (==) FBDEV(0): RGB weight 888
[ 44.125] (==) FBDEV(0): Default visual is TrueColor
[ 44.125] (==) FBDEV(0): Using gamma correction (1.0, 1.0, 1.0)
[ 44.125] (II) FBDEV(0): hardware: nouveaufb (video memory: 9000kB)
[ 44.125] (II) FBDEV(0): checking modes against framebuffer device...
[ 44.125] (II) FBDEV(0): checking modes against monitor...
[ 44.125] (--) FBDEV(0): Virtual size is 1920x1200 (pitch 1920)
[ 44.125] (**) FBDEV(0): Built-in mode "current"
[ 44.125] (==) FBDEV(0): DPI set to (96, 96)
[ 44.125] (II) Loading sub module "fb"
[ 44.125] (II) LoadModule: "fb"
[ 44.125] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 44.125] (II) Module fb: vendor="X.Org Foundation"
[ 44.125] compiled for 1.10.1, module version = 1.0.0
[ 44.125] ABI class: X.Org ANSI C Emulation, version 0.4
[ 44.125] (**) FBDEV(0): using shadow framebuffer
[ 44.125] (II) Loading sub module "shadow"
[ 44.125] (II) LoadModule: "shadow"
[ 44.125] (II) Loading /usr/lib/xorg/modules/libshadow.so
[ 44.135] (II) Module shadow: vendor="X.Org Foundation"
[ 44.135] compiled for 1.10.1, module version = 1.1.0
[ 44.135] ABI class: X.Org ANSI C Emulation, version 0.4
[ 44.135] (==) Depth 24 pixmap format is 32 bpp
[ 44.137] (==) FBDEV(0): Backing store disabled
[ 44.137] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
[ 44.138] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
[ 44.139] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
[ 44.140] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
[ 44.141] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
[ 44.141] (==) FBDEV(0): DPMS enabled
[ 44.141] (==) RandR enabled
[ 44.141] (II) Initializing built-in extension Generic Event Extension
[ 44.141] (II) Initializing built-in extension SHAPE
[ 44.141] (II) Initializing built-in extension MIT-SHM
[ 44.141] (II) Initializing built-in extension XInputExtension
[ 44.141] (II) Initializing built-in extension XTEST
[ 44.141] (II) Initializing built-in extension BIG-REQUESTS
[ 44.141] (II) Initializing built-in extension SYNC
[ 44.141] (II) Initializing built-in extension XKEYBOARD
[ 44.141] (II) Initializing built-in extension XC-MISC
[ 44.141] (II) Initializing built-in extension SECURITY
[ 44.141] (II) Initializing built-in extension XINERAMA
[ 44.141] (II) Initializing built-in extension XFIXES
[ 44.141] (II) Initializing built-in extension RENDER
[ 44.141] (II) Initializing built-in extension RANDR
[ 44.141] (II) Initializing built-in extension COMPOSITE
[ 44.141] (II) Initializing built-in extension DAMAGE
[ 44.141] (II) Initializing built-in extension GESTURE
[ 44.150] (II) AIGLX: Screen 0 is not DRI2 capable
[ 44.150] (II) AIGLX: Screen 0 is not DRI capable
[ 44.150] (II) AIGLX: Trying DRI driver /usr/lib/dri/swrast_dri.so
[ 44.164] (II) AIGLX: Loaded and initialized swrast
[ 44.164] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 44.177] (II) XKB: reuse xkmfile /var/lib/xkb/server-B20D7FC79C7F597315E3E501AEF10E0D866E8E92.xkm
[ 44.184] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 44.184] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 44.184] (II) LoadModule: "evdev"
[ 44.184] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 44.184] (II) Module evdev: vendor="X.Org Foundation"
[ 44.184] compiled for 1.10.0.902, module version = 2.6.0
[ 44.184] Module class: X.Org XInput Driver
[ 44.184] ABI class: X.Org XInput driver, version 12.3
[ 44.184] (II) Using input driver 'evdev' for 'Power Button'
[ 44.184] (**) Power Button: always reports core events
[ 44.184] (**) Power Button: Device: "/dev/input/event1"
[ 44.184] (--) Power Button: Found keys
[ 44.184] (II) Power Button: Configuring as keyboard
[ 44.184] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[ 44.184] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD)
[ 44.184] (**) Option "xkb_rules" "evdev"
[ 44.184] (**) Option "xkb_model" "pc105"
[ 44.184] (**) Option "xkb_layout" "us"
[ 44.186] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 44.186] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 44.186] (II) Using input driver 'evdev' for 'Power Button'
[ 44.186] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 44.186] (**) Power Button: always reports core events
[ 44.186] (**) Power Button: Device: "/dev/input/event0"
[ 44.187] (--) Power Button: Found keys
[ 44.187] (II) Power Button: Configuring as keyboard
[ 44.187] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input0/event0"
[ 44.187] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD)
[ 44.187] (**) Option "xkb_rules" "evdev"
[ 44.187] (**) Option "xkb_model" "pc105"
[ 44.187] (**) Option "xkb_layout" "us"
[ 44.188] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event6)
[ 44.188] (II) No input driver/identifier specified (ignoring)
[ 44.189] (II) config/udev: Adding input device Microsoft Microsoft 5-Button Mouse with IntelliEye(TM) (/dev/input/event3)
[ 44.189] (**) Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): Applying InputClass "evdev pointer catchall"
[ 44.189] (II) Using input driver 'evdev' for 'Microsoft Microsoft 5-Button Mouse with IntelliEye(TM)'
[ 44.189] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 44.189] (**) Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): always reports core events
[ 44.189] (**) Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): Device: "/dev/input/event3"
[ 44.189] (--) Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): Found 9 mouse buttons
[ 44.189] (--) Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): Found scroll wheel(s)
[ 44.189] (--) Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): Found relative axes
[ 44.189] (--) Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): Found x and y relative axes
[ 44.189] (II) Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): Configuring as mouse
[ 44.189] (II) Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): Adding scrollwheel support
[ 44.189] (**) Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): YAxisMapping: buttons 4 and 5
[ 44.189] (**) Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 44.189] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.0/input/input3/event3"
[ 44.189] (II) XINPUT: Adding extended input device "Microsoft Microsoft 5-Button Mouse with IntelliEye(TM)" (type: MOUSE)
[ 44.189] (II) Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): initialized for relative axes.
[ 44.189] (**) Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): (accel) keeping acceleration scheme 1
[ 44.189] (**) Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): (accel) acceleration profile 0
[ 44.189] (**) Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): (accel) acceleration factor: 2.000
[ 44.189] (**) Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): (accel) acceleration threshold: 4
[ 44.189] (II) config/udev: Adding input device Microsoft Microsoft 5-Button Mouse with IntelliEye(TM) (/dev/input/mouse0)
[ 44.189] (II) No input driver/identifier specified (ignoring)
[ 44.190] (II) config/udev: Adding input device Logitech Logitech Dual Action (/dev/input/event4)
[ 44.190] (II) No input driver/identifier specified (ignoring)
[ 44.190] (II) config/udev: Adding input device Logitech Logitech Dual Action (/dev/input/js0)
[ 44.192] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event5)
[ 44.192] (**) Eee PC WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 44.192] (II) Using input driver 'evdev' for 'Eee PC WMI hotkeys'
[ 44.192] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 44.192] (**) Eee PC WMI hotkeys: always reports core events
[ 44.192] (**) Eee PC WMI hotkeys: Device: "/dev/input/event5"
[ 44.192] (--) Eee PC WMI hotkeys: Found keys
[ 44.192] (II) Eee PC WMI hotkeys: Configuring as keyboard
[ 44.192] (**) Option "config_info" "udev:/sys/devices/platform/eeepc-wmi/input/input5/event5"
[ 44.192] (II) XINPUT: Adding extended input device "Eee PC WMI hotkeys" (type: KEYBOARD)
[ 44.192] (**) Option "xkb_rules" "evdev"
[ 44.192] (**) Option "xkb_model" "pc105"
[ 44.192] (**) Option "xkb_layout" "us"
[ 44.192] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event2)
[ 44.192] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 44.192] (II) Using input driver 'evdev' for 'AT Translated Set 2 keyboard'
[ 44.192] (**) AT Translated Set 2 keyboard: always reports core events
[ 44.192] (**) AT Translated Set 2 keyboard: Device: "/dev/input/event2"
[ 44.193] (--) AT Translated Set 2 keyboard: Found keys
[ 44.193] (II) AT Translated Set 2 keyboard: Configuring as keyboard
[ 44.193] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input2/event2"
[ 44.193] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD)
[ 44.193] (**) Option "xkb_rules" "evdev"
[ 44.193] (**) Option "xkb_model" "pc105"
[ 44.193] (**) Option "xkb_layout" "us"
