minumin graphics agp
27 Mar 2004
Telford
well after my 6600gt died, i need another card, will be used for web and video(divx, dvd) only no games have my 360 for that, so i am looking for the minimum also would prefer nvidia only,would a nvidia 4200ti do?
also i am thinking of maybe running a second monitor from the same pc what would be the minimum card then
thanks
After finally being able to concentrate after staring at your sig pic, the ti4200 will do fine.
You'll struggle to get a silent one though, I had a Leadtek Vivo one and it was noisy as hell.
Should get one for £10 to £15. Else a Fx5200 with a silent hs
if your not using it for games then get a 6200. has working hd video acceleration so its the ideal card to use. passive cooling too.
6200 agp can be had for under 30 quid and its gonna be the far better option for what your going to be using it for. either way its up to you.
