Mionix Zibal 60 Keyboard problem
22 Jan 2011
Hey guys, I'm kind of new to the forums and was wondering if you could help me with an issue I'm having with this keyboard.
I'll get straight to the point, The keyboard will sometimes go faulty, by which I mean all of the LED lights will turn off and Caps lock, Scroll Lock and Num Lock will turn on and the keyboard will spam the last button pressed even though I'm not pressing it down. To fix it I have to unplug and replug in the keyboard. You guys will understand how annoying that would be.
Do you guys who own this keyboard know of this problem and know a solution?
Thanks,
Rob
Would, if possible, try the keyboard on another machine and see if it does the same. Sounds like it will be the keyboard for me though
I've had the keyboard for nearly a year now and it has been doing it since about a week in. I was fed up with it by the second week. I haven't found a fix for it, but I've found it's much more likely to bugger up if you're trying to go into the BIOS and pressing DEL every second on start up. When I was doing my overclock I had to unplug and plug it back in about 8 times in one day - normally I'll have to do it every fortnight.
I have an Asus motherboard, so I doubt it's anything but a keyboard problem.
It might be something to do with Asus MB. My Logitech G15 used to do that, altho not very often and my new TT Meka has done it twice so far in 3 months; dies suddently and i have to unplug/plug after which is fine. It doesn't really bother me as it doesn't happen often, annoying tho.
