Mionix Zibal keyboard
18 Dec 2003
heybridge, nr maldon, essex
hi
i own ones of these. nice to type on, i don't use it for gaming.
my q: is there a way to keep the lights on permanently? i cannot see anyway to do it.
Would like to know this as well. Was not bothered at first, but getting a bit fed up with having to manually light up the keyboard.
How do you mean, when the PC is off?
When the PC is on you have to press the key next to the left Ctrl and F12 to light the keys (once for WASD, twice for all keys lit.)
Other than this, it is a great keyboard and love the Cherry Black switches.
Ah, ok. It is a bit annoying I must say but still, for the price now it is really good.
I bought mine second hand on Ebay for more than they sell for new now. :o
A quick google shows that due to the fact there is no memory within the keyboard it cannot save the previous state, so in essence no there isn't a way to do it physically.
However, i'd be surprised if this couldn't be written into a script using something like autohotkey or similar software. I have scripts running all the time on my computers due to the fact my keyboards are ANSI layout and i don't have physical \ and | keys so i press windows key + z and x respectively. It's necessary as i use them a lot for programming. Not really a great fix, but it works for me and may work for you in this instance!
got one of these and its the best keyboard i have ever had :)
its no biggie just hold the key and whack f12 twice then f11 twice im used to it now takes like a second or 2 :)
+1 ... for the price this keyboard is class. No nonsense mechanical keyboard nice little touch to allow the wasd keys to be lit up also
