31 Jul 2016 at 18:17 #1 Dimi Dimi Associate Joined 10 Sep 2008 Posts 1,662 Location London Hi, What's the best option for this? I want to play the games I do on the device on my PC. Wireless or wired? Do I need an HDMI cable etc.
1 Aug 2016 at 09:18 #2 Deleted member 651465 Deleted member 651465 Physical connection is always going to be more reliable, so you could try one of these (link). I know there are airplay apps available for the Apple TV which also do this, but I don't have any experience with the iPhone apps.
1 Aug 2016 at 10:10 #3 Christine Adam Christine Adam Associate Joined 11 Mar 2016 Posts 4 Apple is quite strict with the mirroring app in this aspect.You may check this post and see whether it works for you.
25 Aug 2016 at 14:42 #4 kraziboy kraziboy Associate Joined 26 Jan 2009 Posts 3 There is software called reflector, which uses AirPlay to mirror from iPhone to Mac/pc. (The software goes on your pc/Mac). I've used it for my iPhone 6 and Macbook pro with great success.
