Hardest part without guns is easily the car decks of the boat, ch7
First deck is easy:
Out of the truck, disarm first guy (he's looking the wrong way), toss the weapon and run ahead on the left hand side (dark/shadowey) and jump the boxes - should lose the bad guys for ~5 - 10 secs. Forwards and left are 2 trucks - jump up the bonnet and then to the roof of the one nearest the wall. From the roof wallrun, turn jump and climb the venting.
Second Deck:
There should be a respawn after completing the first deck so I'll go from there. Run forwards, down the ladder, and into the corridor. Turn right away from your objective and run out to the cars. 1 guard out to the left - run straight at him, slide kick, run round the back and quick disarm. Toss the weapon, 3 left.
Back into the little corridor and try to bait another one out into the open - can be lured quite easily. Usually one in the cars at the other end of the corridor, one by the opposite side and the guy with the heavy MG in the middle. Personally I try to hit and run the guy by the cars which provide cover.
After that you may be best waiting to heal if your damaged and rushing the heavy MG guy dropkick, 3 punch combo should have him reeling but you will draw fire from the other guy. Run away again as all the guys have limited health. Repeat until dead.
If your feeling fancy try the slide/disarm method too. Run at them, slide/enter slo-mo and look up at them. Weapon turns red and hit Y :>
Rst of the game is easy
