Ok, better start this fom the beginning.
Against my better judgement I recently bourght Mirrors Edge using...and it pains me to say it....EA digital download.
So I use EA Download Manager and have variouse issues with it, partly where the program itself was installed and then where it stored the files for installing the game.
OK so I install the game and it works but I get an error at the start saying "Cannot locate save file, your progress will not be saved".
So I reinstall and now the game wont work, crashes at splash screen. I reinstall 3 more times and finaly get it right again, only to get the same error
"Cannot locate save file, your progree will not be saved"
I am guessing this is coming up due to me having my HD partitioned and my documents stuff is on a differant drive, I have my OS on C: and games/files/my documents etc etc on D:.
I'm using Vista btw.
Can anyone shed any light on how to fix this issue? I've tried variouse forums, searches and even EA support which was useless, so am at a complete loss.
M installs to, where it's cache files are held, and where the games install to.
