15 Sep 2014 at 18:33 #1 JDMtom JDMtom Associate Joined 21 May 2014 Posts 13 Hi All, Just a quick query regarding memory. I currently have 2 sticks of 4gb in my pc. If I was to add a further 2 sticks of 2gb. Would this cause any detrimental effect? Cheers In advance
15 Sep 2014 at 21:44 #2 Captain Captain Soldato Joined 1 Dec 2011 Posts 21,465 Location SW3 It would be fine, but make sure you do it 2GB/2GB --- 4GB/4GB to keep dual channel enabled, will you be using the exact same memory? If not, i think you'll have to run the memory at the slowest speed sticks. Last edited: 15 Sep 2014
15 Sep 2014 at 23:41 #3 JDMtom JDMtom Associate OP Joined 21 May 2014 Posts 13 Yes both sets are exactly the same apart from size, So at the moment I have it as follows looking down on the board : 4gb/2gb/4gb/2gb Is that correct?
16 Sep 2014 at 05:28 #4 Captain Captain Soldato Joined 1 Dec 2011 Posts 21,465 Location SW3 Yeah that's fine mate that will support dual channel
