Hi All,
My Volvo is a wee bit poorly... (2003 S60, 2.0T SE)
Symptoms: I was tootling back on the M6 and came off for me to notice my EML flashing, the car felt choppy and noticed a reduction in power. Took it to get the fault codes read and it was miss-firing on cylinders 2, 3 and 5. (Later on 4 also after a few days)
My first garage were thinking along the lines of the coil packs being borked and suggested I take it to a dealer or indi Volvo garage (Of course I did the latter)
The diagnosis started and over the course of no less than 5 days they have 'said' they ruled out the following:
I had a text this morning asking him for me to ring me and he came out with this:
He thinks that the fly-wheel is 'bent' after a nut off the clutch cover has come off and trashed it and a sensor (Which he belives is causing the misfire?) and wants to rip the gearbox and clutch.. now does this particular explination sound plausable? Because the garage obviously want the labour of diagnosis which as you can imagine if it is as serious as this.. it probably isn't even worth the value of the car...
On a side note I do genuinley feel the car is giving me a middle finger as at the time I was on my way to test drive a new car :/
Any help appriciated
- Coil Packs
[*]Injectors
[*]Compression
[*]Plugs
[*]Ran with no CAT
[*]Fuel pump
