Missing Graphics Card & Monitor...
26 Feb 2004
Hampshire, England.
Hi guys,
I’ve just come back form fixing friends broadband connection (Driver issue with modem – fixed!) and she pointed out a couple of other problems she’s been having… :eek:
Basically, she can’t setup either a monitor or graphics card? As a result, the screen is slow and games are unusable?
I though these shots might help you ;)
I really don’t know what to do next? It’s a ‘Time’ machine, which I considered top be my first handicap – although she has the original drivers CD? But there are absolutely loads of possibilities… And I can’t just update the device from the CD because I don’t have that option?
Any ideas?
Thanks in advance!
SW.
I would remove the monitor from Device Manager, and see what happens.
If that fails, remove monitor from DM, then uninstall graphic card.
Thanks for the reply mate - I forgot to mention that the GFX card isn't visable in DM :eek:
SW.
Nevermind guys; all sorted! I just installed the nVidia graphics/system driver? I think she may have deleted it :eek:
Cheers,
Sam.
