- 28 Mar 2005
- Reading
Hi,
Recently changed my motherboard (GA-P35-DS4) and various other existing components, so I'm still using my old HD which had XP Pro already installed on one partition. The other partition is programs and data.
I installed everything without a hitch, but came to boot up from the nlite copy of XP Pro I had made (with SP2 slipstreamed), from my IDE DVD driver. Formatted the system partition ok, and afterwards it began to check the disks. Said it couldn't read the operating system from the disc (even though it was reading it before).
Now when I boot, I get missing NTLDR - press ctrl/alt/delete to restart.
I set the boot priority to CD rom first etc, but no joy. There are options in the bios to change the sata to achi, which I did prior to installing and I think this is what has caused the problem (see http://en.wikipedia.org/wiki/Advanced_Host_Controller_Interface).
Will resetting cmos help?
Is there another workaround that anyone is aware of?
Or would I be better to install xp on another hard drive and start from scratch?
Thanks
Bornslippy
Thanks
Bornslippy
