- 10 May 2004
- Sunny Stafford
I know the answer to this problem - I have a burning question about it. The error message appears as white text on a black background just after the PC POSTs. It reads as follows:
The solution is to boot into the recovery console using a WXP CD, copy the default registry from C:\Windows\Repair in place of the bad reg files. This brings the PC back to default. To get the last-known-good reg files, you have to go into C:\System Volume Information and copy from there.
I work on a helpdesk for disabled students and I often get bugged with this problem. In year 2003, I implemented this fix 3 times. 2004 and 2005 were free from this problem. In year 2006, the problem came back and I had to deal with it no less than 10 times!
It only happens with Windows XP. The other burning problem I get is when the PC goes into a reboot loop no matter which option you press on the F8 "advanced options" menu. The fix is to run a chkdsk /r on the recovery console. Again, only on WXP. I have dealt with this problem on 18 PCs now. I have never seen these 2 problems on my own PC but it is very common amongst customer PCs. Any idea on causes?
Thanks.
Code:
Windows XP could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM
Thanks.
