missing points?
This happened because the EOC stats were taken down for a few days for a database clean.
You've lost no points as the project was returned to the server just fine. The high peak you see was when EOC went back on line and caught up.
Best place to take issue is on the foldingforums. Points estimates are more accurate with client 7.4.2 or 7.4.4. You would only have gotten near the 18k if you folded that unit to completion in one session with no pauses.
tbh, 18k is a low estimate for an 8900. What gpu are you folding on? Are you using your passkey?
If you look through the logs for the time the unit was returned to the server it'll tell you roughly what points you actually got for it.
i only get 18k as i am only folding on a gtx650ti, yes i have paskey, the rig is folding 24/7
yes i know the high peak is when EOC came back on line but mu gap is after that and can be seen in the hourly graph by its absence as a big gap in the middle (today) i will look through the logs...i have not looked at them befor
EOC updates in 3 hourly segments, in turn relying on the stats updates from Stanford. I often see an effective lag of 6 hours between my submitting a WU and it being credited on EOC.
yes i often see the lag but i have had 5 completed wu since my missing one 3 by the 650 and 2 by the cpu i have just looked at the log and i am going look again tonight when i have more time to decipher it
When i say its folding 24/7 thats not quite true as i sometimes pause it when folding say a 8018 as the pc is to laggy to use but with a 8900 it seams ok so it probably didn't get paused
